Fuel pump runs on and on and on
Engine mods, conversions, turbos, gearboxs, drive shafts
Postby Tidzy » Thu May 30, 2013 7:26 pm
sometimes if you turn car off you can here the fuel pump still pumping.... it dont stop
any ideas?
Tidzy
Postby miles1234 » Thu May 30, 2013 10:19 pm
Sounds like a dodgy tachy fuel pump relay , swop it with a good spare .
Postby MAD-PUG » Thu May 30, 2013 10:20 pm
Tachometric relay.
MAD-PUG
Postby craigoodwood » Fri May 31, 2013 7:33 am
if the car stalls the pump will keep running anyway, it sounds like the tacho relay has failed in a different way to normal they usually fail and dont pump, you'll find it under the steering wheel next to the ecu ;)
3dr goodwood
5dr goodwood
5dr 850 T5
craigoodwood
Postby Tidzy » Fri May 31, 2013 8:23 pm
took the relay out and cleaned it out with electric connection cleaner and she is sound now..
thanks guys
Tidzy
Postby Tidzy » Fri May 31, 2013 8:24 pm
thanks guys
Tidzy
Postby MAD-PUG » Fri May 31, 2013 9:13 pm
craigoodwood wrote:it sounds like the tacho relay has failed in a different way to normal ...)
It sounds like the contacts inside the relay are sticking together, in which case the problem will possibly return, - unless you opened the relay casing, and cleaned inside it.
MAD-PUG
Postby Tidzy » Fri May 31, 2013 9:29 pm
yeah i stripped it down mate totally....
Tidzy
Postby Tidzy » Sat Jun 01, 2013 3:28 pm
nope its knackered..
need a new relay
Tidzy
Return to Engines & Transmission
