Badgeless Grill
Changed your clutch, removed the engine? Let us know the pitfalls and what to watch out for
Badgeless Grill
Postby eyebrows » Wed Oct 14, 2009 7:38 pm
Well i hope this helps anyone who is interested in making a badgeless grill. Unfortunatly during the process i forgot to take a couple of pics but its easy enough :-bd
My origional idea was just to take the badge out and cut the right lengths to fit where it went. But you could see the back plate and i didn't want this.
So i decided to cut this section out
Then i used the first top bit again when finally fitting this bit i packed loads of fiberglass between it and the top part of the grill to hold it.
Then i masked the lower sections and marked them up. As you can see i used a piece with the support in so this will act as the new middle support for the grill.
I then trimmed/cut to size. Better to cut a bit big and file the last bit :-bd
I forgot to take any pics of this bit!
Happy with the fit i put 3Tonnes of fiberglass on the back of the grill. I covered both bottom slats on the back and joined the small fin i left at the top of the pic below to the top section of the grill. Any fiberglass visable from the front i filed down when it was dry.
Then i filled and sanded until i was happy and then filled and sanded till i was a bit more happy.
Then i cheated a bit i used PLASTIC FILLER PRIMER. I did this to make sure i had filled it all properly!
Then i sanded it again and gave it another coat
Then i gave it a light sanding and a couple of top coats
I was supplied with cellulose spray paint which i dont nomally get so the colour isn't exact if get offered this again i won't be getting it :-q
92 3dr Goodwood slowly being restored DOB: 14/11/1991 Build no:5484
96 Golf GTI my Daily Driver
51 Golf 2.8v6 4motion Clare's Daily Driver
309 Goodwood GTI Register
[email="goodwood@309ownersclub.com"]goodwood@309ownersclub.com[/email]
eyebrows
Re: Badgeless Grill
Postby CosKev » Wed Oct 14, 2009 7:45 pm
Good write up and pics numb-nuts :-bd
Will look great when you park up on the local super market car park now!!!!! :) ) L-)
:D
2.0 16v 306 Rallye,the new daily driver.........
2.0 16v VTS powered '91 White 309 Gti fully restored daily driver,SOLD........
'99 Evo VI rolling shell......Work in progress......
CosKev
Re: Badgeless Grill
Postby Brian » Wed Oct 14, 2009 7:50 pm
Very good how to, looks much easier to do than my attempt with the 206 grille. It's in 2 parts and far too flimsy as it's quite long when joint together so it cracked in the centre :( Just bought an ecosse grille and now I dont know whether to fit it or not :) )
Brian
Re: Badgeless Grill
Postby HimBigChief » Wed Oct 14, 2009 7:54 pm
Only problem I've found with the debadged grill is that the front end can look like a Mk3 Escort from some angles when at a distance...
Other than that, nice write-up!
Image Image
Project Goodwood .................................................. 406 2.1TD Executive
HimBigChief
Re: Badgeless Grill
Postby tonho51 » Wed Aug 04, 2010 1:20 pm
fantastic tutorial! Should have a lot lot more than this to help out all the newbies like myself!!!
tonho51
Return to Dummies Guide to....
Users browsing this forum: No registered users and 1 guest
