HELP Aerial removal
HELP Aerial removal
Postby ravcon » Wed Jul 29, 2015 4:37 pm
Hi all how do i remove the aerial on a 309? mines kinda just spinning around and i have no clue why..
ravcon
Re: HELP Aerial removal
Postby miles1234 » Wed Jul 29, 2015 8:50 pm
You will need to remove the roof console by your rear view mirror then you should see a shiny metal cap with a pink cable going into it from the side , that is your aerial . Grab the cap with a pair of pliers and it will pull off , underneath is a bolt which by the sound of it is already loose . There is a tiny plastic pip which sits in a small hole in the roof and stops the whole lot spinning .While you are replacing it put a little bit of silicone sealant round the thread and pip to stop water leaks .
Do not force the roof console as the plastic is brittle with age , remove the interior light by prising it down and it can be gently slid out ( if its a GTI there is a small screw holding it in place )
