[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4752: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4754: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4755: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4756: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
Welcome to the International Peugeot 309 Owners Club! • View topic - Car weighing/corner weighting service at various 2018 events
Postby miles1234 » Mon Sep 04, 2017 11:13 pm
I will be bringing my Intercomp E-Z weigh race car scales along to 6 or 7 car shows/track events in 2018 , I will be offering a service to weigh your car , measure the corner weights and check wheel camber ( both with and without the driver ) with all information provided on a comprehensive data sheet .
I will post the events that I will be visiting as the dates are released but I should be at French car show , Pugfest at Prescott hillclimb and a number of events at Santa Pod like retro show .
[ by , on Flickr*]
miles1234
Re: Car weighing/corner weighting service at various 2018 ev
Postby miles1234 » Mon Sep 04, 2017 11:38 pm
I have set my scales up on flatter ground than that in the photo above and then levelled all 4 pads using a laser levelling device to within 2mm with packing under the appropriate pads .
I checked that I was happy with the ride height that I had set the 309 to and made sure all the tyre pressures were correct at 30 psi .
With a 1/4 tank of fuel and no driver my white 309 weighed 903.5 KG , Left Front 267.5 KG , R Front 270 KG , L Rear 181.5 KG , R Rear 185 KG . Cross weight is 49.92 % .
miles1234
Return to Shows and Events
Users browsing this forum: No registered users and 0 guests
